Hello all, I am stuck. I have a 1994 1FZ-FE OBD1 cruiser with 314k miles. I recently purchased in June 2026 and have been trying to get it to run smoothly. I have an ongoing CEL code 25/26. Instinctively I thought this was most likely bad O2 sensors. I replaced them with Walker O2 sensors and installed them where the PAIR device used to be (in the exhaust header). The code went away for a few weeks and the truck seemed to run smoothly except for an occasional surging start when cold. The truck now has a rough idle and rpm’s drop when under load. It almost sounds like a diesel truck the way it idles, kinda choppy like. It’s almost like a cylinder isn’t firing with the way it vibrates. There is a slight clicking sound when accelerating as well.
I do not believe this to be the O2 sensors because they are reading correct voltage/ohms and even when I unplug them and reset the code, it still idles rough when the ECU should be compensating and giving it a richer fuel to air ratio with an open circuit.
One odd thing with my Oxygen sensors is that one side reads the upper limit of 5v while the other is the lower limit of 0.08v when viewing from my OBD1 diagnostic port.
There are no vacuum leaks, just replaced all vacuum lines, no cracks in the intake air hose. Fuel pressure is good, sits around 37psi at idle and jumps to 45psi with a quick tug on the accelerator cable. Just replaced all spark plugs, ignition, cables, distributor cap, and rotor.
The only thing I think could be the issue is maybe bad injectors or possibly an air leak that I cannot find. Lmk y’all’s Thoughts!
