After replacing the O2 sensors, the vacuum modulator, and the vacuum starting valve, and then ignoring the damned thing for several months, I think I may finally be able to proclaim victory over the 25/26 rich/lean CEL.
Took my 1993 FZJ80 into the dealership for diagnosis. The quickly called with a "bad O2 sensors" result, replaced them under warranty, and then got the same behavior--I told them that would happen.
Further diagnosis finally led them to the PAIR valve, which was apparently sticking open, leaning out the exhaust, and the presumably causing an over-compensation leading to a rich condition.
They replaced the PAIR valve, and all seems well. CEL has been off for record time. The tech said it was a very rare and unusual problem, "last line on the last page of the troubleshooting guide" sort of thing. 25 and 26 codes seem to be relatively common gremlin codes with the 1993 - 1994 FZJ80's--keep the PAIR system in mind when troubleshooting.
Hayes
Hayes
