cdl
Adelaide/ sa
can anyone tell me if i can put my tranfer in low with out the shaft from the cdl in? i need a new cdl moter and when i put it back in temp. i left the shaft that goes in side the transfer out. its the one with the cog locking thing on the end of it. going beach driving this weekend and not sure if i have to put it in low if it will try to enguage something thats not there and break something?:confused:
bump for you so hopefully you'll get an answer from someone smarter than me :)
Not sure what shaft you are talking about but I assume it is something within the CDL actuator/motor? I would assume you will be fine and nothing will happen when you shift into low other than your CD still won't lock and you'll be in low range.
My only comment is that without the ability to lock the CD then beach driving may be quite the adventure. All of your power will try to go to whatever axle and tire has the least traction. And, without the CD locked you won't be able to lock the front and rear axles either if you are so equipped.
