Bumping this CDL thread as I'm having the same issues on my 2.5" lifted 1995 80 series (with no gear, rear seats, running boards, oem grill bumpers) all removed, so more like 3" lift with camber on the differential that I haven't corrected besides installing a Delta panhard lift bracket - if anyone knows what part of the car is suffering the most from this please let me know.
Problem: No CDL light, no ABS light, no A/T light when moving between 4L-N-4H. CDL feels locked and drivetrain winding when actuated into D and 4L (actuating = In N, moving lever from 4H to 4L is bumpy - and when moving from N to D or R car lurches with loud noise and shifting accelerating from first to second gear causes a gnarly lurch)
Attempt 1: Replaced front CDL sensor with no washer -
1) no changes.
Attempt 2: Replaced rear CDL sensor with thicker washer -
1) CDL light and and A/T light
2) no ABS
Attempt 3: Replaced rear 4L sensor with thicker washer and added CDL switch in dash
1) no CDL
2) no A/T light
2) no ABS
Driving to the gas station with the CDL switch in dash pressed in randomly turned on CDL light only, pressed it again and it turned off, and wouldn't turn back on
Attempt 4: Cleaned all electrical contact points, pushed in the balls in sensors back and forth, added thinner oem? washer to front CDL sensor, replaced new rear 4L with the old one
1) no CDL
2) A/T light on in P and N
3) no ABS
Drove around a dirt road in S shapes in 4L trying to shake it up but nothing, and pressed the switch in while driving a bunch but I just bought 2 oem sensors and plugging them in with oem washers to see if that works
