CDL Switch
I am sure that this has been covered before, but I thought I would share an enexpensive option for the CDL switch:
I have tracked down and purchased an inexpensive rocker CDL switch. I am going to use it until the proper funds become available for the "Toyota" switch.
The switch is a double pole double throw with an on-off-on configuration. I am only going to use on 1/2 of the switch so 3 of the 6 terminals on the back will be unused. Cost was $6.00 at my local electrical supply store.
Here is a link to the switch.
http://www.colehersee.com/catalog_top/index.htm
Look under the switches, rocker type, part# 58027-07.
Harness
Here is a shot of the harness that I built using the factory harness. I added one more pin to the harness plug.
Have you operated it yet? Does it work properly? That looks like a great install. :cheers:
Switch
Yes I have used it and it works great. The right position is off, center position does nothing, and the left position locks the center diff.
I have a picture of the factory wiring harness that shows what terminal does what, but I am having trouble uploading it.
