CDL switch question
Boston
I have a 93 80, ive been looking through the cdl threads and don't see many on , the curved dash switch. im just making sure im doing this right. is this the switch i need? will the plug in be behind the dash for this. i do not have lockers.
this is the one i thought i needed , but after looking in the threads i don't see many people using this one. or placement. ill include some photos of my current dash.
8472560010 Genuine Toyota SWITCH, CENTER DIFFERENTIAL LOCK 84725-60010 | eBay
Typically, the CDL switch is located above the climate controls above your A/C button.
The harness is directly behind that panel and is not typically long enough to go anywhere else. Many repurpose a hazard switch fir that location and relabel it.
thanks@
thanks! so the ebay link is the correct switch?
do i just dremel out the opening?
thanks!!
thanks@
thanks!!
Yes, that's the correct one. No you dontd Dremel anything. You use a blade to pop out the switch cover in the dash, you remove the bezel around all those climate controls, and remove the climate control body. The harness is behind there. There are a few screws to get there and a few spots to pop it loose. DontD get in a hurry and make sure the interior is warm before you start or you will break stuff. Then pop the new switch into the hole, plug in the harness and put it all back together.
I
I have a 94, same dash as yours. That's the part number/ part I used . It will fit above the climate control in the blank spot beside your rear De-fog. Connector will be hiding back there and from the factory has a thin wrap of foam around it and is connected to a blanking plug with a single wire that loops back in to the connector.
thank you. any advice on taking out the dash
hello all, just took apart my dash in preperation for the cdl switch. My clock is also broken and i ordered another one but i cant figure out how to get the top panel off i took off all the screws and the one hidden in the right side, i dont want to break it by pulling!! Ahhhhh
This is the connector the the cdl switch
I used an ECT curved switch on my '93. These tend to go for real cheap unlike ones that say CDL on them. Plug pops right in the switch and switch pops right in the dash.
There are screws going up into the dash pad above the instrument cluster. I think it then just pulls straight out.
how do i get off that top panel with the clock on it
I attached a page out of the FSM that some kindly sent to me. I hope that worked. Once all the screws are out there are a couple of clips at the corners that hold it in place IIRC. A gentle pull straight out should release them.
