Hey Fellas,
So a buddy of mine have been at it for about 4 hours trying to figure this out. My CDL is stuck on and we have gone through the various threads to try to figure out how to fix this.
I have a 1997 triple locked (from factory) with the 7 pin and CDL switch mods done. My CDL light and ABS lights are on and regardless of how many times I press the CDL button it doesn't disengage.
I have replaced the 4wd indicator switch (old one looked fine, but now I have a spare).
I have exercised it hundreds of times while driving on loose dirt and doing figure 8s in every direction possible. The looks you get while doing this are entertaining
Lastly we tried to listen to the actuator to see if we can hear it running. We couldn't hear anything so assumed the actuator was gummed up or ceased. However after we got the CDL actuator off and opened it up it was super clean. We were actually disappointed as we thought we had this narrowed down as the issue.
So we tested the actuator by hooking it up to a battery. After a few tries the drive gear began to move, we reversed the polarity and the drive gear moved the opposite way. We thought we had this figured out, but we were wrong.
We then hooked up the wires of the actuator to the truck and cycled the CDL switch a few times. The actuator gear (thats held on by a "c" clip) would move but very slowly and only in ONE direction.
My impression would be that each time you press the CDL it should move clockwise and counter-clockwise (engage/disengage).
So it seems my actuator is working, but only in one direction which I am assuming is the locked direction. Any ideas why it would only be moving one direction?
I want to get this done so I can move on to fun mods. I have a 4" lift waiting to go on, but want get the 4wheel drive system in order first.
Thanks in advance,
.Lastly we tried to listen to the actuator to see if we can hear it running. We couldn't hear anything so assumed the actuator was gummed up or ceased. However after we got the CDL actuator off and opened it up it was super clean. We were actually disappointed as we thought we had this narrowed down as the issue.
Thanks in advance,
