My CDL wasn’t engaging at all, the button had no responce from the tranny relay, and the 4L only activated the 4l and not the CDL indicator light on dash. After following the troubleshooting manual posted on this page i found my problem. My CDL actuator motor was stuck looks to me by mud and humidity built up inside. I unplugged the actuator motor it has 5 pins, 3 on one side and 2 on the other. I used a battery to apply current directly to the motor. The side with 2 cables that are slightly thicker than the others are the ones to check. Positive cable to the middle pin ground to the outter pin will lock the actuator motor and ground to the middle pin and + to the outer will disengage the CDL. That was actually ehat fixed it.
Now before anything els, before this i checked the indicators, pulled them
Out and seemed good, luckily a buddy bought an 3fe so i swaped tranny relays, swaped the CDL button and nothing, bridges current on the indicator and light was good so ended up working with the actuator...
Probably i should open the actuator motor and clean and lube the motor but for now ill wait
Note: make sure you apply current till motor turns all the way till open or closed or you will make the problem even worse. If this seems to happen when you press or un press the button you will have a significant voltage drop and cdl ligjt will stay on even when button is taken of.
Just wanted to share my experience and how lukily i fixed it for free
Thanks for sharing that troubleshooting the CDL
