CDL on?
Montrose, CO
I put a CDL(hazard) switch in my 97 this weekend but, I'm not getting any sort of dash light to indicate anything is working. Other than the possibility of a bum switch how do I find out if it's coming on? It's on jackstands right now awaiting the new tires on the freshly powder coated rims;) so taking it for a drive is out of the question. Any ideas on where to look first?
No need to do the 7pin mod, but may as well. With the CDL switch installed, put it 4L, you should be able to lock the center now by just using the button. (in other words it won't lock just by putting it in low like before).
Did the center work before installing the switch?
Try turning your ignition switch to the "on" position, where all your dash lights come on, but don't crank up your engine. Shut off your heater/ac blower motor, your stereo and any thing that makes noise. Put your head down where your feet normally are when you're driving. Reach up and hit your new CDL(hazard) switch. You should hear the relay click as the CDL engages and also when it disengages. If you don't hear this, report back, because we need to help you find out why this isn't happening. This is basic and should indicate if your switch & CDL are functioning. The dash CDL light may still not light, but that's another issue that doesn't always give an accurate indication that the CDL is locked.
P.S. If it is quiet enough, you should also hear the approx 1 second whirring noise down under the rig, in your transfer case of the actual CDL motor. If you hear the relay, but not the whirring, try tapping on the case of your T/C (top side near the CDL motor) with a screwdriver handle or something similar.
Perfect.
Hit the switch, then get under the rig and see if indeed the two driveshafts are locked together.
:meh:
I don't think 1 person will be able to check this on a full time 4x4 with a working VC. This is a good check for part time rigs, but not our full time system with the VC.
Why do you think one person can't do it? :confused:
If all wheels are off the ground (vehicle on jackstands), then:
1) Tranny in park, T-case in high.
2) With center diff. unlocked, spinning either driveshaft should result in the other driveshaft spinning in the *opposite* direction.
3) With center diff locked, it should not be possible to spin either driveshaft.
4) Now put the tranny in neutral (leave the center diff. locked). Spinning one driveshaft should result in the other driveshaft spinning in the *same* direction. (I.e., the driveshafts are indeed "locked" together.)
I don't see where the VC has anything to do with the above tests. :meh:
Curtis
Thanks for the ideas everyone. Now at least I've got ideas on what to check out. I'm not gonig to be able to mess with it for a few days due to that four letter word(work). I should be happy just to have a job I suppose. Oh yeah and the 80.
Curtis
Curtis, your suggestions make sense. My concerns were that a working VC makes the transfer case act like a limited slip CDL and would affect the outcome of your tests. I've never tried what your suggesting, myself, but like you said, with the rig already up on jackstands - most of the work's already been done. The rest is the fun part. I also didn't think that one person, by himself, could physically do the testing. But your steps explain it pretty well. And the important thing is to see if the CDL is locking. Your steps 3 & 4 check that pretty well.
Had a spare 5 minutes to check things tonight. Had the garage door shut and no radio or anything else making noise. I turned on the key, pushed the switch, and...............................I am rewarded with a little whirring noise followed by a click. Push the button again and whir followed by a click. No light comes on but I can definately hear it engaging!!!!. Thanks to all for your thoughts and possible solutions.
Good job! Now you know it's actually engaging the CDL. The lights (CDL & ABS) are controlled by a switch on the front top of the transfer case. This switch is notorious for being troublesome. You can verify that your bulbs in your dash work by pulling the connector on the harness and shorting the contacts with a paper clip while some one up top is watching the dash lights. The switch asm can be removed from the T/C quite easily. IIRC it's around $65, so you might want to try fiddling with it. I had success by dousing it with solvent and working the heck out of it with my hands. Proper operation can be verified with an ohm meter. With the age of our rigs, the little ghosts like this seem to multiply, sometimes. Like Retro says, it sometimes takes the vibration of the gears inside the T/C turning and the heat of the tranny, motor & T/C working to get the switch to close and light the dash lights. Good luck!
