CDL Locker Light
South Kansas City, MO
I'm just going to throw this out for one last ditch effort before I go to the stealership.
Chronologically here is what has happened
1. CDL light would not come on when engaged
2. Tested CDL being engaged via jack and drive tests, both passed. Its definitely engaged
3. Jumpered connector on transfer case and Diff light and ABS light come on...GREAT its just a switch
4. Oredered replacement switch
5. Replaced D light and PWR light in cluster (burned out)
6. Installed CDL switch and performed pin 7 mod
7. Recieved and installed diff lock indicator switch in transfer case
8. Diff light and ABS light dont illuminate even tho you can clearly hear the center diff engage and feel the binding while driving.
9. Jumpered connector and now the lights dont illuminate
10. Reversed pin 7 mod for good measure still no lights
11. Performed the relay tests as outlined here and everything passed. Troubleshooting the Toyota FJ80 Land Cruiser Center Diff Lock (CDL) | Pacific Northwest Backroad Adventures
12. Pulled cluster and checked light bulbs and connectors (ABS light illuminates when the key is turned forward but not when CDL is engaged) swapped bulbs around and definitely not a bulb problem.
13. Tore out what little bit of hair I have left out and drank uncontrollably.
14. Fuses checked
15. CDL switch removed and jumper reinstalled
NOTHING!
You can definitely hear the relay click and the CDL engaging.
Please if you have ideas...I'd love to hear them. I will buy you multiple beers or the drink of your choice.:beer:
Thanks in advance.
You and I are traveling on parallel roads....
Did you ever solve this problem?
I checked out mine and a new bulb fixed one cruiser but not the other. The problem rig is doing exactly the same as yours, CDL definitely engages but no indicators.
The is a 4wd Indictator switch on the tranny. I think its the one towards the engine. You can remove and jump it with a paper clip to test.
IIRC it's a ground activated circuit, there should be ground on one connector at the switch all of the time. The switch is open when unlocked, closed when locked, so when locked you should have ground on that wire all of the way to the light. This sounds like a bad connection problem, connector corroded, terminal pushed back in one of the connectors, etc. IIRC the main ground connection for that circuit runs other things, so if it were the problem other things wouldn't work. Hook a test light or volt meter to a hot wire, and test where you have ground or not.
A very remote possibility is the CDL actuator is not timed properly or bound, so it moving enough to shift the gear, but not enough to activate the switch? Do you have continuity across the switch when it's locked?
ok mine does this too.... i'm interested in finding this out... and i'm a little slow... can someone explain better what the 7pin mod is and what vehicles are capable of it? sorry....
ok thank you..... I was just confused on what vehicles were capable and needed this operation... i see now... pin 7mod is now on my list of do's along with auto up...... has anybody heard anything on the light yet???
OMG
Looks like I am going to be going down the path of installing a CDL in my 93 and doing the 7 pin mod. Currently mine lights up "some times" when I shift to 4L but not each time. I need to get to the root cause of this first before I do the CDL install. I am getting ready to install a new radio so I figured it would be a good time to install the switch (as soon as I buy one from Slee).
AZ:clap:
AZ:clap:
Keep in mind, shifting in to low wont always just enable the CDL. Once in low the splines need to match up in order to engage.
The CDL switch you refer to is a easy short install.
