CDL indicator IE Dash lights.
Twin Falls Idaho
My CDL indicator light doesn't come on in the dash. I can hear it locking and the lights in the button work but not in the dash. When I turn the key to the on position with the engine off it doesn't light up either. What lights should come on when the key is in the on position engine not running? I want to see what bulbs I need to replace and how to replace them.
Thanks bro. I guess I get a little post happy and forget the search button. Hey can you tell me if that is the front or the rear output shaft on the Tcase. Now mine is locking just fine but I guess that just controls the indicator? How does the CDL sensor get removed fromt the T case if its bad?
front drive shaft, IIRC the switch/sensor has hex sides and threads out, there are two similar switches on the tcase, one looks for low and the other looks for locked.
My dash light doesn't come on for either one. I'll try the jumper thingy and see if the dash light works if so I'll be calling DAN like everyone else.
