CDL electrical confusion
Sorry for the long post but this is a long time coming.
I need some advice on where to go next.
I have searched and read all the good threads that have been posted but mine seems to have taken a strange twist.
My CDL and both diff lockers have never functioned correctly and I am trying to figure out whats going on.
I thought I had got it figured out but no.
I replaced the CDL sensor but still no lights.
Then I thought it might be the 4-lo sensor but it tests okay.
Then I decided to jump the cdl sensor and lights come on but still can not lock the front or rear.
I then decide to jump the rear sensor and that light comes on.
So I take it out and test it on the bench with a 9V battery.
It works great. Wish I had tested it before taking it off.
So then I get clever and use the 9V on the CDL and low and behold I hear it lockup, reverse polarity and unlock, then I lock it again.
At least I don't have to take that bad boy out.
I then try to move the rear actuator shift fork manually but its not lined up
(or stuck)
So I jack up the DS rear wheel but can not turn it because the center is locked.
I am happy to know that both center and rear actuators are working but still stuck.
So I unlock the center.
I try to manually move the rear fork and with a little turn of the wheel it slides over easy. (Now I know thats okay)
So my question is this:
I know the CDL is working but when I shift to 4-lo I hear the relay click but the CDL is not locking. What do I need to do to determine if the CDL is actually getting power sent to it? I am beginning to think the relay is bad or I have a short in the wiring.
Any advice is greatly appreciated
Bill
Ah, I'm so close I can taste it.
I was rereading the e-locker thread and realized I was right at it.
I just need to test pins 2 & 3 on the female side of the connector going back to the CDL relay. I assume I will be looking for a 9-12 V signal to move it.
I am seriously wondering if I just put it all back if it will work.
