Applying current to the switch will not do anything. it is just a switch. It allows current to pass through when it is closed.
Just getting movement of the "ball" (plunger) is not the problem. In fact I have never seen on which will not move. When the TC lock (or the axkle lock) engages is HAS to move. It is just not passing current when it closes. Over time the electrical contact surface(s) within the switch can deteriorate. Sometimes burnt, sometimes just dirty with trace amounts of residue from the gear lube that is in between the surfaces every time they close. Sometimes rapidly working the plunger in and out a LOT may clean the surfaces so that the switch functions. But it will often be not long before is it balky again.
FWIW, I have not heard much negative feedback on the beck arnley or other aftermarket switches. But a few of the guys who are local to me have not had good luck with them. Getting OEM or denso units has always worked perfectly.
Mark...
