CDL/ABS light trouble shooting
Mission Viejo, CA, USA
I have a '95 FZJ80 that was probably never off-road in it's first 144K miles, and I've only used it mildly because it's not yet armored. In the few times I took it off-road, I was never able to get the CDL light to illuminate, and the ABS light only comes on at starting. I installed the CDL switch, and after messing around with the relay box behind the DS kick panel I finally got the relays to click and the CDL to lock. I confirmed the lock by observing drivetrain binding on a hard surface.
With the CDL switch engaged and the CDL physically locked, neither my ABS nor my CDL light illuminate. I know the ABS light works from start-up and I doubt the CDL lamp is is bad. Any suggestions?
Pull the center diff. indicator. It's located behind the CD actuator on top of the T-case. Check to make sure it is functional, and replace if necessary.
I had the same problem with mine. One of the contacts in the indicator was broken. A quick call to CDan, a couple of days, and problem solved!
:cheers:
