Ccot Ac
Has anyone installed this unit and if so how do you like it? I am looking for an AC unit for a FJ40. I have had one with vintage air, which did a good job heating and cooling but I never could get the vacuum valve heater hose shutoff to work correctly and the microswitches were problematic. How does the CCOT unit work?
The CCOT unit is merely AC. You retain your original heating unit. My 45 and 42 have the exact same unit that CCOT uses and it works pretty well--especially well in the 45 (smaller cab). I had more difficulty due to having to adapt to diesel units, 24volt electrical system, and RHD for the 45. It's very straightforward install into a 2F-powered 40.
I installed a vintage unit and completely did away with the micro swtiches and vacuum valve. Worked well. I used the stock heater valve and wired the AC turn on to the previous fan control in the dash.
Is it acctually worth it to spend the time and money for A.C.
I live in Colorado cold winters/hot summers
