CC Bushings Question
Charlotte, NC
Hey guys,
I've got a '96 with an OME Heavy Front/Medium Rear lift with an ARB and Warn M12000 in the front and I still have the stinkbug effect. I currently have the OME CC Bushings in the front arms and it drives good but the steering wheel wobbles when I apply the brakes. Now I'm thinking about getting Slee's 1" Front Spacers to level things out, but if I do this, do you think I'll also need to replace the OME CC Bushings with Slee's 3 degree CC Bushings?
you steering wheel wobble is probably from your front brake rotors being warpped. Try having them machined or better yet, go with the slotted/drilled rotors at Slee and the 100 series pads. LC are very heavy and eat brakes.
As for the CC bushings, 3 degree bushings will get you closer back to the stock specification fron Toyota. Also, you might need to add the spacer for the sway bar.
Check out this link and scroll about half way down to read about the castor and spacer info: Slee - Lift Size vs Tire Size - Slee (Toyota 80 Series Land Cruiser)
I didn't think the slee spacers were an option, they were out of stock for quite a while. I have been wanting to do a similar setup.
... do you think I'll also need to replace the OME CC Bushings with Slee's 3 degree CC Bushings?
What is your caster number with your current set up?
-B-
