CC bushing installed....
not sure if i made the right shop choice for this work....but they ended up having to keep the truck over night and charged me 3 hrs shop labour to remove the control arms and press in new bearings.
I just hope they blasted them in properly using landtanks template.
After the first drive the truck seems to track a little straighter, especially through some of the rutted asphalt roads we have up here in calgary.
Truck might seem to pull gently to the right, which is something i didnt notice prior to the bushing install.
At least they are installed.
i noticed a little more pull after my lift. I think it is due to a) taller rig being affected by the crown in the road, and b) if properly set up you will most likely have a little more caster on the PS which will cause it to pull a little.
Glad you got them done!! I noticed a bit more lift on the front end once mine were pressed!! I also noticed that my return to center was better (faster).
Side note I sold that rig, and get my new one on Thurs.... Look for pics on Friday!!
let me know the next time you go wheeling!!
Mine also pullled a little more to the right. But it was due to LESS caster on the passenger side (0.3*) vs. (1.1*) on the driver's side. At least that's what the alignment shop found and told me was why it was ever so slightly pulling to the right. So they are saying I need a little more caster on the PS to help bring it to center.
Does anyone knnow what the effect of more or less caster on one side will do? will less caster make the car pull to that side or pull to the other side? I was going to pull my control arms and re-do the passnger side to get more caster in hopes of evening things out and making it not pull to the right? i just want to be sure i am on the right track before i exacerbate the problem.
Leroy, perhaps i have it backwards, but it has been pointed out to me once that more/less castor on the passenger side is normal and will cause pull. The thought was it came from the factory with a little more/less (which ever the frickin' number is :) ) to deal with road crown.
Also, do you have spacers in?
I had Mr. Gasket spacers in and once i removed them and the medium springs and installed just J springs, it tracked much better. The pull was a lot less. Don't know why.
