CB's...Fixed vs. Portable
State of Flux...
I'm shopping for CB's and want to know what others think about portable units such as the COBRA HH38WXST vs. fixed mounted units such as the Uniden compact 510. I really like the idea of portability but I don't want to sacrifice coverage distance and such. Please provide your input so I can feel better educated before I pull the trigger on a new CB. Thanks :idea:
Does anyone have pics of their CB's mounted somewhere other than below the radio or in the ash tray slot? if so...please post'em up. Thanks
A fixed ham radio and a portable cb with an external antenna? Works for me.
Hi,
I have two of those Cobra Walkie T's....used once...even have an external mag mount antenna for one. You can have them cheap.
They don;t get out worth a damn...
If you want to be heard...try this...
* Magnum S-980 (sideband / 80 Watts) or a Magnum S-680 (AM / 80 Watts)
* PowerStick 2 Antenna mounted on Roof
* Really good quality Feed Line
* DP-56 Microphone
A great setup
I bought a hand held (portable) from Radio Shack and have found that for trail use it is more than sufficient. In fact, I had better reception than many of the fixed setup rigs last time I really needed distance to check in with a group tending to a broken axle (in the mountains from a distance of over a mile across varied terrain - nothing even close to line of sight).
The think is that most people put an antenna on a corner of the rear bumper for clearance reasons. I can't get technical about this other than to say that is about the least ideal place - you really need it in the center of the roof, which really doesn't work for wheeling.
Bottom line: if you only use CB offroad or to listen to occasional trucker chatter in a traffic jam, a hand held is a simple and effective choice. If you really need long distance reception, you aren't going to get it without causing issues in mount location.
I have the Midland portable thats available at Walmart for like $89.
I just used it out on a trail run with a few FJ Cruiser guys and it worked fine for a tight group (within a mile of eachother on the trail).
Im sure I'll eventually upgrade (since if I ever break down, there's no guarantee anyone will be within a mile of me.....) but it works fine for now.
Forums I have browsed about the Midland say that it pretty much does not work at all with the little rubber antenna on the unit inside the car. I paid another $10 for a magnet antenna on the roof....and the CB already came with an external antenna adapter that is coupled with the cigarette lighter power cord.
bump
yep, that is exactly it... i am going to get a huge tall antenna for the front of the ARB that i can take on and off. that will be the best option i think. i cant stand the magnet ones on the roof. just takes too much away from the truck in wheeling photos! :popcorn:
What model of antenna is it that is collapsible / folds down when not in use and attaches to the upper tabs of the ARB? Also, please post any pics of fixed mounted CB's in locations other than below the radio or in the ash tray slot.
I have the radio shack mini job with a magnet antena. I have a cig adapter to power it and keep in console when not in use. when wheeling I stuff the cb between the pass front seat and the center consol. I keep the portable antenae in the back. cheap cbs blow IMO. I personally think wheelers should give up cbs and use the family talk radios you get at walmart for 20$ a pair. they work well with no tuning and you can take them out of the truck to spot people. and you dont have to run antenae. many now come with headsets and hand free operation. cbs are just old shool. let the truckers have them
hardcore types should have their HAMS and its great when a few in the group have a nice cb so you can seperate if you need and call back to camp
You can use one of these fold-overs.
http://www.walcottcb.com/203ez-fold-over-adapter-p-262.html
I have one and it works great, I believe Romer has one too, or at least he had one at one point.
I've got my antenna and fold-over mounted to the aerial mount on my TJM. I use a velcro strap to hold it down when not in use.
What's the average distance a fixed CB can travel? I want a CB for when I'm out solo on the trail and need to communicate with other wheelers or rescue / emergency stations...and listen to truckers jibber-jabber when traveling.
You need to read up on mounting. When you put an antenna out on a corner of the vehicle performance is drastically reduced no matter what the actual CB unit may be.
There are no standards or averages - a mid priced based unit with antenna mounted in the best location for the vehicle will likely far outperform a pricey unit with antenna mounted out on an ARB brush guard.
If you are talking about being out solo and hoping to use a CB to communicate for rescue, you need to go to a CB shop and have your requirements professionally assessed (they should be able to test the best place for the antenna).
Having said that, these days a cell phone is much more likely your best bet, not CB.
A post above said it right - wheelers need to ditch CBs and just go with your basic "walkie talkie" units. That's why I didn't buy a fixed setup for my 80. I just take my handheld and I've had it working fine offroad in mountainous terrain for over a mile, which is as good as my Cobra fixed unit with 4' Wilson antenna mounted to the rear bumper ever did.
At least Google the subject and you can read up on why mounting location is so important.
understood...I'll probably just get a $75 COBRA HH38WXST and call it a day. Thanks all for the input...:beer:
I only got a CB because so many out there already use them, wheelers that is. But that being said, I keep a set of Cobra FRS/GMRS radios in the 80 at all times that I'll give to people following/leading me because their range and performance is better than a CB, at least in my experience.
Since I've always had mutliple trucks the choice was easy...Midland portable with Radio Shack Mag mount antenna been using it for 6+years, always works great. Portable attachable stubby antenna is nice if you want to talk out of the truck to others in the group.
