So I mounted a 3ft Firestick on my ARB and the AWR was around 4 using a calibrated NanoVNA. I though that a ground strap may help, but that brought it to an SWR around 7.... I am going to run a CB with a footwarmer (way offload only), so I really need to bring that down. Any suggestions other than removing the ground strap?
You need more ground plane; flat sheet metal perpendicular to the antenna like a roof top or a hood are ideal for this. If you're set on keeping it mounted to the bumper, then try a longer antenna that will project above the plane of the hood more.
