cb antenna mount
El Paso TX
what is a good antenna mount for the hood channel. i want to relocate mine from the top of the roof rack to the hood. by moving it there would i get better or worse antenna strength. my thought is the higher the better. what do you think?:cheers:
There's more to it than altitude. Having the correct amount of ground plane (the conductive horizontal surface on which you mount the antenna) will help your signal. Try Googling the specific antenna and specific CB you have and see what other people have done to optimise their performance.
I have heard that the more to the center of the vehicle is usually the best. You get a bigger ground plane that way. Signals transmit downward and reflect off of the metal roof. So I would say that on the roof just behind the sunroof would be the best spot. Now I have also been told that the sunroof doesn't help because it is metal?
That's true. The center of the roof is the optimal position. The other very important thing is to properly ground the antenna to the car chassis. I successfully tried my luck with grounding the antenna only with two screws (see picture below).
It is temporary installation but it works. The problem with temp stuff is that it is usually lasts for ages. ;)
I have searched my archive and found some quantitative data for the above installation:
SWR 01 - 1.1
SWR 20 - 1.4
SWR 40 - 2.2
It is really decent result bearing in mind the effort and resources.
I use a Lil Will mag behind the sunroof and it works great. It is also easy to reach if you need to take it down on the trail, bank drive thru etc.
ok thanks. i cant mount it in the middle of the roof because i have a roof rack. thats why im thinking on the hood. i have it on the roof rack to one side. it creates a problem in low clearance spots. oh well thanks again for the info.
izzy... do you have to tune the antenna on those channels when you are tunning the antenna?
