Cause of bobble 2 months after painting ?
(still in the learn & do phase)
Did body fill with Duraglass and finished with duraglass (polyester) glazing putty.
Sanded to fine finish & wiped w/ denatured alchohol (hmmm, might have used lacquer thinner....) & let dry well.
Did not use primer.
Painted with OMNI AE MAE.
Two months later, I have some bubbles (blisters ? ) only in the area where I did body work. Other areas ( painted on existing, sanded, paint) don't have them.
It's like an air bubble under a vynil sticker; paint is flexable, bubbles moves a little when pressed upon...
The Question : What causes the bubble ?
Thanks
Pete
I've never tried painting directly over body filler without primer, but it's a case of adhesion definitely. You either have poor adhesion, or rust. Guess you named the problem up front. Primer is porous and accepts the paint with a good grip.
definately agree with texx.
