Catalytic converter
Sacramento
Quick question...........My cat is about 2 years old and it began to raddle last night. I figured out it was the cat because I can tap it and hear that it is coming from something inside that broke. Does anyone see any problems with just gutting it for a temporary fix? I was going to cut it open and gut it, then reweld it shut, just so I don't hear the rattling everytime I come to a stop....thanks:cool:
Not a good idea, especially based on your location. You might get with who ever mfg. the cat ans see about a warranty if the housing isn't beat up.
kinda figured that but just a little anoyed with the noise.......Unfortunatley it was installed in L.A. and I'm in Sac so warranty is not an option, this sucks.....everyone wants over 100 bucks for an oem type. For some reason all the ones I find are 1 inlet 1 outlet and for mine its 2 inlet and 1 outlet. Not sure what the deal is with this, so let me know if this is normal....thanks
It looks like whoever did the install in LA screwed you good, that Y-pipe that came stock is pretty tough to remake and probably made him another $50-75 bucks, a single 2-1 cat is also not factory and probably wont pass visual if you're getting tested by someone who is strict by the books.
I'd say gut it and be done with it, but you don't cut it open. You just remove it and take a piece of rebar or similar and pound and poke it all out. Wear a dust mask, don't touch the stuff inside with your bare hands, and make sure you get it all out.
CRAP.......thanks for the input.....It gets worse because there are no flanges for me to just remove it. They completely cut and welded so its part of the header and part of the whole damn thing.......holy sh$t this is not good. Maybe can cut it off then gut it like your saying and reweld it back in.....
That is what you're gonna have to do. You can start putting some penetrant on the header/downpipe bolts, and just end up cutting one end and possibly using a band-clamp instead of re-welding it.
Thats a good idea, I think I am going to some how bring those two pipes together first so I can have 1 inlet 1 outlet. Then I will use those clamps. thanks for the help.
Here is the pic of the Cat, I diddn't realize how clost the O2 sensor is so I am in a jam with this now, I am not sure how to approach this, like you said, I barely have any room for anything......I know I will be cutting something this weekend.....:crybaby:
