Catalytic Conv. Relocation?
California
I live in California. I have a 91 FJ80 with the stock exhaust setup. I browsed the forums a bit and couldnt find anything about cat relocation.
My question is... Has anyone moved their cat from the stock location with success? Are their any pros/cons with moving it further away from the engine? Last but not least... Do the california emissions laws have anything to say against moving the cat from the stock location? Im searching away as i write this. Any help would be greatly appreciated!
They do not function properly if they are too far from the engine. Are you having an issue with heat? If so, gut the catalyst from the cat and add more heat shielding above them. Then they would pass visual inspection for the emission commies.
No im just trying to get creative with the soon addition of my sliders. I dont want to route the mount under the cat, id like to have a straight tube to the frame. So im trying to figure out if i can move the cat somewhere else :D
I moved mine back and over, next to the driveline. No issues, passed (Arizona) emissions with flying colors.
-Spike
-Spike
Did you run the pipe over or under the frame?
Put a 1 inch body on it and re-route your exhaust over the frame.
I've done the body lift and plan to reroute the exhaust over the rail. I will also be cutting and turning the cats (90*) at the same time, which should tuck them up above the frame rail.
Total cost quoted was $350 for rerouting the exhaust and doing a cut and turn.
I got a new exhaust from the Y pipe back for ~$500, including a new muffler and cat.
-Spike
-Spike
That's a good price.
I was told several times that it'd be cheaper if I went with aftermarket cats and muffler, but I wanted to keep it as OEM as possible.
Flyrod has one cat up tight out of the way. I'll be doing the same very soon. There's a great muffler/fabricator over in Ashland. I'm going to remove two and replace with one. Bob
I'm going to be going to TOY350's guy in G.P. His quote was a LOT cheaper than anyone elses, including Flyrod's guy.
I considered going to one, but decided not to as it seems that a fair amount of people (including Flyrod) have had issues with codes being thrown.
It works though.
Be aware that in California you have to pass a visual and sniff test. Any deviation from stock could send up flags and cause you to fail the visual portion.
With that said, there are a few people in Cali that have gone to a single cat and still passed. More likely if your "cat protection" makes it difficult to see the cat(s) itself, a lazy tech will assume everything is OK and rely on the sniff test only.
Awesome feedback guys! I think ill just route the slider mount under the cat for the time being. When the funds come in, ill reroute the exhaust over the frame and back and remount the slider straight to the frame for greater strength. :cheers:
I spent allot of time trying to avoid mounting around the cats on my 91 and just broke down and did it. I removed all the heat shielding and replaced it with a really tight to the cat cross member for my sliders along with a skid plate to protect the cats.
