CAT removal
hillbilly desert rat
A buddy is trying to talk me into removing my cats.Increased power maybe. Anyone running a 3FE with out cats. Besides the legal thing. Will it affect anything?
There is no inspection on vehicles in my area. I will keep them in a box just in case the state begins a emission testing program.
Thanks D
I (may or may not) have run with hollowed out cats in the past on a minitruck. This will get you past a visual inspection. I had stripped off EGR and all "emissions" controls. This thing was straight forward: Weber carb in, headers to free flowing exhaust out. Interestingly, when we hooked it up to check emissions, it ran cleaner than similar stock minitrucks.
I got rid of my cats and never regretted it. First point is improved ground clearance. Who wouldn't want that? Next point is comfort. Your feet don't feel like they are in an oven. On any long uphill a lot of the heat put off from those cats goes right through the the shielding. Even slow crawling built up more heat than I was comfortable with. And with the O2 sensors ahead of the cats w/ the 3FE, mine never popped up any CEL codes. My cats were chopped out and thru pipes installed. I can't say that it gave it more power because that 3FE is still just a 3FE.
No power increase or gas mileage, the only thing I noticed was it was a little louder and the heat on the floorboard was not there. You wont get codes because yours is OBD1, 02 sensor before the cats.
:cheers:
