Cat coverter
I have a 95 FJ80 115k miles on it. The PO removed the cat coverters and place what looks like a oval straight thru resonator along then a 40 series flomaster muffler single inlet dual outlet muffler. The truck has been running good my question however is since there is no cat the engine check light was on (untill i disconnected the battery now i dont have it) how does this affect the truck? i know there is a o2 sensor after the cat, does this senor do anything other then for emisions control? Could any one explain why the engine check light never came back after the battery was disconnected? thanks for you help in advance
I can answer that one...
Disconnecting the battery erases the ECU, and consequently, all codes stored in it.
Yes that i understand, but if the cat is still missing wouldnt it come back after a while? It hasnt come back in about 2 weeks, and the scanguage II shows no codes so i dont think is a bad check engine bulb. also sitll question what effect no cat has
Will the SGII read codes on a pre-96 vehicle? The 95 is OBDI, right?
My understanding has always been that the post cat O2 sensor is only there to tell you when the cat is bad and has nothing to do with fuel mixture.
Tony
It does erase all codes, but they will come back if the condition hasn't been "corrected" and in this case it hasn't. The only thing I can think of is that in two weeks of driving, you haven't met the specific conditions that measure the cat condition and enabled the code to set.
Does the CEL come on while the key is ON before engine start? That's the bulb check feature, tell us that. The 2nd O2 sensor is to determine the health of the cat as far as I know. If you were able to look at the output voltage of the front compared to the back of a normal cat, that's what the ECU does and when it doesn't match a pre-set pattern, on comes the CEL to inform you of poor cat efficiency. Drive it a little longer, my guess is it will come on soon.
The '95 is a "sort of OBDII" in that they implemented most of the OBDII features and hardware but Toyota was not under obligation to make it OBDII until '96 model year, therefore some of the functionality of the OBD system is, well... non-functional.
I have a hard time using typical scan guages, they all don't work with my '95.
FWIW. Dan.
Maybe im blind but im pretty sure mine has no after cat O2s, in which case removing the cat should have little effect on the CEL. There is no way for the pre cat O2s to tell if there is a problem with the cats and if there is no after cat O2s then there is no way the rig even knows that you have a cat or not.....as for state inspection time, it depends on where your at, in MO cats are required on any vehicle manufactured after 1983
Ive kinda got the hookup on inspections luckily, as I was planning on gutting or removing my cats entirely they ever have an issue. BTW in 95 most companies were starting to implement some of the OBD2 changes but not all of them (i.e. OBD2 style diagnostic ports with old school cpus etc.)
:cheers:
OK I could see mid 95 models registered as 96 i.e. 6/95 and up build dates
Well i know for sure my truck has a OBDII system cuz the scangague II can read rpms and temperatures real time etc., I do know it obdII was done mid 95 and up, like it was said earlier, and it does have 2 o2 sensors one before and one after cat. My check engine light is working cuz it comes on when first turning the key. Only thing i can think of why the light didnt come back is if the computer changed its parrameters when the battery was disconnected sort of a new starting point to referece to. But that seems like a long shot.
if I were you I would consider getting an O2 simulator like the Honda ricers do when they take out there cats, tricks the computer into believing that the vehicle still has a cat
are you sure its not a aftermarket slim line cat?
also I have noticed that my light would only come on after driving for a little while at like 40 mph steady then it would trip . If I reset it and drove allot of stop/go it would take until I drove steady again around 40 to pop on
yes thats all it would do is trick the cpu into thinking it has a cat, the only function of the #2 O2 sensor is to let the cpu know if the cat is working effeciently, you already know that its not working effeciently because it is gone, so put in an O2 simulator and make it think everything is hunky dory and the CEL will go away (at least until the dreaded 401-402 codes come back LOL)
