Cat, 02 sensor, check engine light
Boston
Website
www.burnmachinefilms.com
Temporally took out the two rusted cats on my 94 80 while I figure out a new exhaust option. Welded in a straight pipe for now.
my question is is there anyway to get the check engine light to go off ?
You could try pulling the fuse in the engine bay to reset the ECU and see if the CEL will stay off. If not and it reappears, plug a paper clip into terminals E1 and TE1 of your diagnostics port on the PS of the engine bay firewall, then turn on your ignition on w/o starting the truck and count the blinks of the CEL to see what code you are throwing. Once you have that, you can search on the codes for an OBDI truck here and then see where to go.
Hmmm...'94, how long has it been since you changed out your O2 sensors? '94 are both before the cats, so I wouldn't think your 'temporary' removal of them would/should make a difference, but I'm only a :banana::wrench:. Everything I know I learned here on MUD and 21 years owning a '94 that eats O2 sensors like candy.
