Castor Issue/Question
Colorado
My LC came with 850's on the front and yellow OME castor correction bushings. I'm getting ready to put in a front DC driveshaft and the pinion is currently pointed high (i.e. slightly above the transfercase output flange)
If I understand the castor issue correctly, you want the axle rotated in a way that moves the front pinion flange to a more vertical position. I need to bring mine down anyway and this should help with the castor although it currently drives just fine. It looks like the bushing were set up for max rotation when the PO installed them.
Has anyone had any luck in pushing out these bushings and re-using them? Does anyone know what the actual diameter of a bushing is? I'd like to use the socket method versus buying a specialized bushing tool.
Thanks,
Adam
