Castor Correct and the press.
CouleeDamWA, BoiseID
Ok.. I did a search.... my brain is about mush right now after dealing with the soon to be exwife and then trying to figure the best route with this CC kit.
Ok it is the Old Man Emu CC kit. I spoke with the only shop in town with a press. They said it only goes up to 12 tons. After reading a few of the horror stories I figured I would at least ask being this is my first time with an 80 and doing a CC install.
The controll arms already have the stock bushings pressed out. So I jsut need to get the OME ones pressed in. I read one of the install in the tech files and it mentioned that if the bushings dont go in correctly they can cause undue stress. So I would like to get these installed properly.
Is there a jig I can barrow or rent or an easy make? I really do not want to phawk this up. I know Landtank has the templetes?
Castor correction bushes are simple to install after you get over the worry factor.
There is room for error here (upto 4mm), The bushes are after all made to flex.
Just measure, recheck and measure again. Press.
I wouldn't bother with a jig if your only pushing one set.
a soldered copper pipe jig would take only a few minutes to make. I vaguely remember reading that there is a pipe size that fits the bushing holes very well. Of course if you have already taken out the old ones, it's a bit late for that but maybe somebody has one?
Not sure if I understand your question, as I used landtank's template to align the bushings as I pressed them in. I used a 20 ton press to get the old ones out and the new ones in. No grease/antisieze/freezing/torching/witchcraft required. Just a big honking press and something to use as a press tool on the bushings (large socket, Slee press tool etc).
A press is a definite requirement for these bushings. If 12 ton is what you've got, give it a shot. FWIW, the 20 ton didn't seem to be straining too hard on my instal
I don't think there is a factory requirement for the press, as the bushings should be a lifetime part. The 20 ton press I used was at the Toyota dealership I worked at, so check with your local shops. One of them might be willing to do it if you showed up with a template and a couple bucks (or beers!)
With mine, the hard part was getting the old bushings out. 12 tons should be more than adequate to reinstall the bushings. Give it a shot.
Tony
anybody tried to use a torch on the arms to make it easier to take the bushings out?
I used an air chisel to cut the center rubber out and then the outer part collapsed pretty easy. Didn't need a press to get the old ones out. Used the cheap HF press to put the new ones in. New ones went in pretty easily.
does Landtank make 2 different templates?(ome, slee) just curious, since the marks are on opposite sides of the 2 different bushings.
the 12 ton will press the new bushings in with no trouble(as stated by others)
I am about ready to install my blues. What was the rating of the HF press you used? I assume the 12 ton? I know they have 6, 12, or 20 ton.
Don't know for sure. It was at my buddy's shop. It may have been the 6 ton but no more than the 12.
If you buy a HF press, replace the hardware that comes with it with better stuff. Years ago we used one and the bolts pretty much blew apart.
:eek: Thanks for the info....
