Carrier Pin torque?
Bay Area, CA
I'm buttoning up my rear axle, and can't find a Torque spec for the carrier pin locking bolt in any of my FSMs or Haynes. I've read about them shearing and creating a major PITA, but the thought of it loosening and getting out is not pretty either. The generic spec for a 8 x 1.25 in the engine FSM is about 12-15 ft/lb. I've torqued it up to 15, I haven't used any locktite on it either. Am I OK going with that?
Also 35 ft lb on the carrier to housing bolts OK?
Hey, check out before and after:
In case anyone is interested, I found a Diff write up on Pirate that recommends 25ft/lb on the spider shaft lock pin. Appears that there's no published value. Anyone have later FSM for chassis that shows locking pin torque?
