Cargo Area Interior Trim Re-Install
Pittsburgh, PA
Has anyone had issues getting this piece back into place?
I had to pull it out slightly to get enough clearance to remove/reinstall subwoofer housing. I believe it is just 4 clips along the bottom of window that were popped out. It now won’t clip back fully in place. There is a finger gap between the window and trim where it normally sits flush after 3 of the 4 clips are back in
I can feel the 4th clip that won’t fasten and it is lined up. If I push on the panel the clip goes through the hole and the panel sits flush but immediately pops back out when I let go
The clip isn’t broken. I swapped it with another one and both do the same thing. The other areas snap in easily and line up as expected. Only thing I can think of is replacing the clip with some sort of bolt/washer and threading a nut on the end after it’s through the hole to secure it
Well, it was 5 clips apparently
Gave a hard random push to the top left side of the panel (which I had tried previously) and the whole thing snapped in perfectly
Pleasantly surprised that no plastic was harmed throughout this operation
