carburetor trouble (W)
Sunny South
i know your sick of hearing about weber carb problems but i know i should get an aisin and chuck the 32/36...but i'm looking for answers to my problem
i have a 71 with a 32/36 with petronix elec. ignition and it has an inconsistant behavior, i took it for an 14 mile trip to my friends house to get work done on it, worked flawlessly and now it won't work....
i start it up to run and it runs for a few seconds then shuts off, in my attempt to stop it from shutting down i try to give it gas and it kills it right away, even the slightest bit of pedal just kills the engine, i recently took it apart and its really clean inside of it and the needle isn't sticking to the seat on the floatbowl setup....i seem to think its flooding because i can see some gas pooling at the top of the float valve (flapper) and when i push down the accelator with my hand on the carb a nice pile of smoke comes up through the chamber in the carb... after cleaning the carb and maybe an hour or so of running the chamber is nice and black as well as both choke and accel.. valve... on the primary chamber
it also seems to be running rich, i recently got all new plat. bosch spark plugs, which after reading it looks like i need NGK's and but i don't think has anything to do with flooding...
what pressure do these carbs need 4psi and high volume? i have a regulator i can slap on there, but i just need to solve this problem
any help is great and i know everyone cringes when they hear weber.... but give me some slack, i'm trying....
webers dont like any more then 2psi to 3psi of fuel pressure, use the regulater. it should help, i had a buddy with the same problem.
why would it only work sometimes and then not any other? seems like a pressure problem would but constant... maybe i just think problems should be consistant (like my spelling errors) and i go from there....
what would cause the smoke comming through the chambers? this carb is only about 1 old, and i didn't install it the DPO did....
where would i find the jet and to see what jet size is on there so i can eliminate that variable... i heard a 70 would suffice but an 80 or 85 is ok
its been a while since i worked on a weber and it was the 38 DGAS so i dont know if they are the same or not, but jets are useually in the float bowl, you could pull the top off but you may ruin the gasket. do a google shearch try redline/weber carburetors i used to have the site saved but cant seem to find it. never been a weber fan so i try to avoid them. i just remember the thing would flood over about 3 1/2 psi fuel pressure. wish i could help more!
