Anyone know why I would have a buildup of carbon in the air intake chamber and manifold on a high mileage 87 4Runner EFI. The carbon is at least 1/4 inch thick. Just old age???
Engine had a problem with the timing chain cutting into the water jacket and the oil was the typical milkshake. I have not heard the engine running, only the PO says it ran fine with no problems except the water/oil mix. Also all injectors were covered with carbon and looked in bad shape, sent out for rebuild. Found some vacuum lines in/out of the intake that were plugged with carbon, one even had a golf tee (they're good for many things
) blocking it off. Not sure how long the engine ran with the water in the oil, but long enough to toast all the bearings and luckily not damage the crank. I haven’t pulled the valves yet, but will in the next day or two. I will be replacing the pistons, rings, bearings, oil pump and or course, timing chain case.
Thanks,
Jerry D.
Thanks,
Jerry D.
