Carb
Hey guys,
I have a 75 with the engine from a 77, front disk brakes and power steering.
The issue is the carb. It is a ford 2 barrell. (runs like crap) I still have the Aisan carb (worked great on the 77). Is it possible to install a 4 barrell or the Aisan with the disk brake resivour?
Do I need to fab something up, or will it fit as is? Is there a write up on this?
Thanks
Spider
I assume there is some sort of adapter on the intake manifold now to allow use of the Ford carb. The Aisin carb should bolt directly to the stock intake manifold (with stock spacer) when the Ford adapter is removed. The Aisin carb will have no interference with the brake master cylinder.
You will need to rework the throttle linkage, as I assume the Ford uses a cable. SOR has good photos of the stock carb set-ups, if you need some guidance.
