carb/vac problem
central california
I need help. My 1980 fj 40, stock with all ca emmission controls in place, wont always idle once the engine is hot. If i try to drive it, then it always dies any time I slow to stop. Sometimes it will idle after its warmed up but its rough .Now I removed all the vacume lines,carb etc to replaced the leaking exhaust manifold gasket. After sitting for months I tried to put it back together the same way it was taken apart . i'm sure that i did it wrong ( the vacume line part )and this is where the problem lies.. I have a toyota emmissions manual but its still confusing .thanks
Welcome to the board.
Retrace the vacuum lines 1 by 1.. Use masking tape to label each hose end as you go through them. THE FSM has a good diagram. IF it helps use different color hilighters for each hose in the FSM and trace them out in the book. Just a way to follow them easier.
Good luck
When I first got mine, the PO or his idiot mechanics had the vacuum lines all messed up. It's a wonder the thing ran at all...
Ditto on carefully redoing all the lines. I'll be doing that again this winter.
Good luck.
