I have an 81' pickup (with shiny new ARBs and longfields
). It will run great for a bit. Once turned off and then restarted, I get the intermittent problem where the truck will not idle unless gassed. Even while driving it will die if the foot comes off the pedal. Then suddenly, it runs perfect and idle smooth again.
The carb was recently rebuilt, and did the same thing before and after. If I crank the idle screw up when it has this intermittent issue, the truck will still not idle.
I cannot find anything wrong with respect to fuel delivery so now am looking at electrical. Can anyone suggest what to check next? Truck is 22R with 110K on it, so still in good shape.
). It will run great for a bit. Once turned off and then restarted, I get the intermittent problem where the truck will not idle unless gassed. Even while driving it will die if the foot comes off the pedal. Then suddenly, it runs perfect and idle smooth again.The carb was recently rebuilt, and did the same thing before and after. If I crank the idle screw up when it has this intermittent issue, the truck will still not idle.
