I think most years can be made to work. I'm sure somebody else will chime in with more detailed info on that subject. Biggest thing to worry about is 79 up has the return at the fuel pump and earlier ones have it at the carb. Do some searching and you'll find that you can work around this, but you'll have to plan for it and find the parts depending on what you decide to do.
It's not going to be as simple as just bolting a different carb on there. I am in the process of rounding up parts to do the same thing on my 80 and this is a starter list of things you need to look into or at least think about before you get started swapping it back.
Fuel pump - that year I think had 2 pipes to the carb. Fuel + a return. Holly only has the inlet, so you'll need to see what they did with your return line and fuel pump.
Hard lines - yours may have been cut or removed. You'll need something that can bolt into a factory carb.
Gas pedal may have been changed with a cable one - may need to replace
Accelerator linkage - various rods & the main torque rod + piece that bolts on top of carb base probably missing
Firewall torque rod bracket + grommets that accelerator pivots on - check if it's missing...mine is
Choke cable - mine was changed with a shorter one. Don't know if that's because of the Holly or if the old one broke
Carb insulator plate - mine's missing
Get correct air filter assembly w/ new filter
Air filter inlet and hose + clamps (if you're going to use it)
Large vacuum line from valve cover to air filter
