Carb bowl emptying overnight ?
Do you have any non-ethanol gas available to try?
If I run ethanol gas in my carbureted truck, the float bowl is empty in the morning. Especially in the summer. I can actually see the fuel boiling in the clear fuel bowl on my fuel pump. When I run non-ethanol I can let the truck sit about a week before the fuel is gone.
I bought a fuel pump with a hand priming lever so I don't have to crank my starter too long to prime it. No it's not a Toyota but I see posts like this in old car, truck and tractor forums. Running non - ethanol gas seems to be the best solution. If it's not available, many have used an electric pump to re prime the system after sitting.
This is assuming you actually don't have any sort of leak in the carburetor.
I’ll have to drive a few extra miles to get non ethanol fuel and plan on doing so . Actually I called Jim C and talked to him about my problem since he rebuilt the carburetor for me and that is what he suggested.
Wow - so maybe it’s the alcohol diluted gasoline available today that evaporates out of the bowl too fast.
At least you’ll find out.
It only takes about 3 revolutions of the starter to put enough fuel into the bowl to facilitate an engine start the next try.
Morning-
Crank over the starter 3 revs to get some gas in the bowl first. Stop. Don’t try to start it.
Then try to start it.
That’s how I always needed to start the engine after it sat for several weeks. Maybe I cranked it 6 revs to prime the bowl first before trying to start it. always started without a fuss after priming.
After trying a few things mentioned above, I don't think the issue has to do with heat or "cook off". I cranked the engine yesterday afternoon enough to start it , then shut it off immediately after it started and let it sit till this mourning. Carb bowl was empty . Looks like I have a leak somewhere. Now to figure out where !!!!!!!
Leave a 1/8 cup of gasoline in an open plastic/glass container overnight. Betcha it’ll be all gone by morning too. Evaporation.
The carb float bowl doesn’t have a sealed cap. It’s open to atmosphere to evaporate also.
Usually a leaking carburetor will leave a trail (stain). If you don't see anything externally, you might have to remove it and look under it. In the intake.
Good luck with it. It's frustrating for sure.
When the ignition is off, The float bowl vents to … the charcoal canister via that big pipe on the side that has a hose connected to it.
The float bowl is always vented through the brass vent tubes.
Mark...
Make sure that the float bowl outside plugs are snug. If one wasn’t tight, gas could weep almost imperceptibly and not be visible as it evaporated - and drain the float bowl.
UPDATE!!!
OSS. Thank you for this info. Both of the float bowl plugs were loose and leaking. I tightened them and now... pull the choke and pump the accelerator twice and she fires right up.
