Car Wash = Wacky Electrical Behavior?
Folsom, CA
I made the mistake of washing my 80 yesterday, something I usually avoid. Not only did I wash the outside, but I cleaned under the hood, both with water and some Simple Green on the dirtier bits. Closed her up and went in to watch the game. Came out this morning, scraped the ice off the windows, and went to drive to work. Immediately the air bag and ABS lights came on and I could feel the ABS actuating without me even touching the brakes. I assumed I had some water intrusion somewhere that would correct itself as the engine heated up, so I drove around the block a few times until both lights went off. I then noticed that the fan speed was varying and found the voltmeter (and the scan gauge) were showing the voltage intermittently going from around 14V to 17.5V, with the red idiot light above the volt meter flickering occasionally. At this point I was becoming late for work and took off, figuring things would sort themselves out as the car dried out. After a 20 minute drive to work the voltage is still fluctuating, sometimes with throttle, sometimes opposite throttle and the air bag and ABS light occasionally flickered on, but no brake pulsing. I obviously got water (and Simple Green) into somewhere it was not intended to go. but don't have any idea where to start looking. I'd appreciate any suggestions on where to start looking.
Thanks,
Ice in CA?
Keep driving it should dry out.
Ice in CA?
Well, we call it ice. I had to scrape it and it was a bit thick. Back in the midwest we would have called it a good frost. Sacramento can get cold this time of year. We had an inch of ice in the pool a year or two ago...
I washed my LX motor once a year and every time after I washed it, I allow the engine to air dry for several minutes by leaving the hood open right under the sun, and use air compressor to blow and towel to wipe any excessive water.
Well, I obviously did something wrong. :rolleyes: Walked out to my truck after work to find both low beams burned out, obviously from the 17.5V they were subjected to on the drive in. Flipped on the fog lights to stand in for the headlights and drove to Costco to fill up and find some decent overhead lighting. I replaced both bulbs and was back in business when I noticed the scan gauge was only showing 12.5 V with the engine running. No change with RPM so I am guessing the alternator is toast now too. It is an AC Delco unit put in by the PO. Unless there is something easy to fix on these (I think the regulator is internal), I will probably be calling Dan for an OEM rebuild tomorrow. Was this alternator on it's last leg and washing pushed it over or does Simple Green have some special alternator-killing abilities I haven't heard about? Luckily the air bag and ABS have stayed blissfully off this evening...
For the record, an OEM reman alternator from Dan is running $238 + $30 core. Mine just arrived. Thanks Dan!
