Can't lock from outside
Eicca
Professional Noob
Utah
I've had this problem for a while but it's about to become a real issue. I can't turn the key to lock on either door. It's not a problem with the key itself as none of my three keys can lock the car from outside. When I try to turn it in the lock it just jams. As if it's the wrong key.
Anything I can do?
Will it operate the rear hatch key slot? Do you use all three keys regularly? Do you usually use the keyfob to open the door? If so, your keys are probably worn down but your ignition still works cause it wore with them. I had the same problem. I had a new key cut from the worn one and it worked my door locks even though the old key would not.
Mine has a similar issue. Drivers door works as normal pass door only unlocks, and the rear hatch does nothing.
That's pretty much exactly what I'm dealing with. Thanks for the info. I'll get it taken care of asap :)
