Can't get diff. plugs out-socket slipping
Actually, don't do this. I doubt a single diff plug in history has ever been removed by drilling and using an easy out. Those plugs get stuck really tight sometimes, and easy outs break off before delivering that much turning torque.
Change that to one in history. This is how I removed my stuck and striped/round plug. Worked like a champ. The only issue is you tend to drill a hole through the plug so be careful of shavings.
Wow, that easy out 'suggestion' was, well, not nice. You should be a lot clearer if you're joking- there are people looking for help on here that will take suggestions like that as gospel.
Like I said, worked like a champ for me. I think I wound up using the big 1/4 or so easy out. Those aren't that easy to break.
i did the same as eckles did and it worked like a charm. 6pt 15/16 socket and use a grinder to grind the face of the socket flat so that more of the socket can contact the nut (which is a litte thin and probably is the source of a lot of the problem). good luck.
Had same problem on my 60, used dremmel to cut slot and used dull flatblade to turn it and tap it loose
I had this exact same thought about 20 years ago, but never
wanted to "hurt" one of my sockets; Ya think I have thought about it
long enough?.:doh:
g
first: hit w/ wd40 or the like
second: hit it with a hammer. Hard. But don't hit the edges or it'll just booger the plug more
third: get a 6pt socket. if it won't fit on gently, hammer it on. Hard
fourth: use the handle of your hilift as a breaker bar (or a heavy plumbing pipe). apply pressure smoothly and hold it for a while even if it doesn't feel like it is moving.
fifth: don't hit yourself in the face
I've had some success using a tire-iron cross w/ breaker bar on it. gives you somewhere to push/pull and less likely to slip off. though that is tough on the drain plug.
I your "second" thought, I think you're missing the fact that he has the replacement allen head plugs ready to go. Since all he's trying to do is git these bastards out, he can trash 'em. But that's what I love most about MUD, you get everybody's idea of the best way to do things (and everybody is right!).:D
x 1,000,000 on 6 pointers.
QFT.
I wish more auto makers would adopt the weird bolts BMW uses to mate blocks to tranny cases. It's like a external Torx or something. It locks into a socket like a PB & J samich when you slap it together.
who sells the allen head drain plugs?
g
CruiserDan stocks both the allen head drain (magnetic) and fill plugs.
-B-
g
They are available from the dealer. Cruiser Dan is a dealer rep with good pricing.
Edit: Beo beat me to it, but only because I had to go to dinner between writing and actually posting. :D
-Spike
Maybe I missed something but did someone say to try welding a nut on top of the existing stripped one?
Yes, actually easier to weld a bolt onto the existing one. Gives you a new head to grab, and the heat can loosen the plug- the one I had to weld ended up coming out by hand.
-Spike
i had to weld a bolt to mine ...took it to the local high school and had some ag guys do it for me....even then the amount of force used was crazy to break the bolt loose...tip the guys some cash... and had some fun while we were at it...
Seriously. give it a smack with a hammer before you do anything else. A good whack and it'll come out easily. Just about very rookie who has driven the Rubicon has learned that you only have to smack the front diff into a few rocks and the plug just winds it self out. I've only had to weld a nut onto a stripped one once and, as was said before, once it cooled it came out by hand.
You can sometimes get a pipe wrench on the fill plugs. That worked OK for me once on an old rounded off plug. The drain is tough, and the welding process will loosen the corrosion in the threads, making the turning out much less traumatic.
Actually, one has been so far, and another will be tomorrow.:D If you don't mind getting oily, it works. I don't know what kind of crappy easy-outs you guys use, but mine work fine.:rolleyes: I will also be doing this to my T-case fill-plug. When a pair of vise-grips cranking on a plug won't get it to budge, you ain't gonna find a socket to get it off. I tried everything else I could think of.
However, do only use this as a last resort.
And yes, I am being a bit of a smart-a about the easy-outs you guys are using. Everybody needs a good ribbing every now and then.;)
Cool, but when your easy out breaks off in the plug, don't come cryin'.:flipoff2:
I hate easy outs, and attempt only as a last resort. Those external things that were briefly posted looked like they might work.
The welding a nut thing takes 30 seconds at best and works great. Do that if there is any doubt.
