canoe?
I've carried a canoe with a bikini top and no top using front and rear tie downs and a cam strap or rope over the center to the roll bar. The canoe was basically balanced on the roll bar and top of the window. It worked better without the bikini as I recall. The windows in a soft top might interfere with a solid tie down over the center of the boat and you might get some rubbing on your top. I was carrying it on my 64 FJ which has a very solid window structure. No problems with it, although I only carried it about 50 miles. It was a 65+- pound 18' canoe with wood gunwales. No damage to the cruiser.
On my 75 I welded in a piece of 2" pipe approx 6" long next to the frame rail on the rt side and the same in the back, I had custom bumpers, Then I made a "T" with 1.5' pipe that was just over the hard top, The T would slide into the short 2" piece. I drilled holes in the short piece and the 'T' so I could lock them in and the canoe would ride on top. All you would see is just the short pipe when not hauling...
