Cannot remove PS rear wheel
bluto
More questions than answers.
North of LA County
Searched but no luck finding anything on how to remove a rim stuck to the hub of the axle. All studs are right in the center of the lug holes of the wheel and it seems the wheel is stuck to the hub. this is the PS rear wheel.
I was able to remove the DS rear wheel but noticed some rust stains on the rim surface that faces (sits) the axle hub. Im assuming the opposite wheel might be in the same condition.
Grabbed the tire and wiggled and kicked the crapped out of the rear PS wheel and no movement at all. Did not do anything else involving prying the rim off as it might damage the wheel or something. Thought about PB blaster but these are the brakes.
Any suggestions? Itll be nice to remove the wheel to change the rear brake pads.
Thanks for any suggestions.
95 fzj80 184000 miles
Tap the center of the axle flange hub with a sledge hammer. Or another way is to put the lug nuts back on loosely and put the vehicle down on the ground. The weight should move the rim enough to break the bond. When you put it all back together, make sure to clean the rust off with a steel brush and I always apply a little anti-seize to the rotor face that meets the rim and on the threads of the lug studs.
Thanks MoGas. Ill try the second suggestion first...
Finally came off! :mad: Tried the MoGas' second suggestion and didnt work - realyl stuck!
Drove the truck around with the nuts tight but loose (not torqued to spec :D) and backed up and hit some curves with the problem wheel. Got home still stuck so I kicked the hell out of it again and finally got loose.
Thanks MoGas for the reply. :cheers:
