1. unless you want to move your truck more than once to grease the drive shafts you should pay attention to where the zerks are,
2. whatever gets them out, I have turned both the head and nut, depending on access at each flange, for some reason they seam easier to remove via the head witch is backwards of most applications, might have something to do with the washer area of each.
3. yes it does matter, these parts are not perfect, each one has a heavy side and a light side, when it was made the drive shaft was balanced as an assembly, changing just the u joints them selves should not change the balance enough for you to notices any vibration but moving other parts around could, drive line vibration is difficult to find and costs money for fix, a little work here can save you down the line.
mark the flanges to the t-case/diff before you remove the shaft and when you get the drive shaft out clean it before you separate the slip spline and before you remove a u-Joint and make a mark a line from end to end with a paint pen, you may find the factory mark at the slip spline if it has not faded too much, that would be a good reference point, re-assemble in that order confirming that the arrangement it came out in matches the FSM as far as phase, my 96 manual calls for front shaft 90 degrees out of phase rear shaft in phase,
