I used to put "8.4" all the time but my fingers got lazy
Regardless, if I get a Diamnd front, it will have an "8.4" in it.
Ive got a couple of Taco diffs if you need one. No 410s though![]()
The axle housings are seriously trussed and his steering arms are super beefy, one offs that plug into both the top and bottom knuckle studs.
Back on topic here, OpTimUs, I see nothing wrong with your Axle specs. Diamond makes some super bling gear, but with some work, the Yota housings can hold up to lots of abuse.
Either way.... just add $$$.
Flame suit is on.
Tached out
woa that cool.
Is that toyota junk?
I can't stay with 4.11 R&P because 80 series chunks (I will have an 80 series rear) dont have gears made in 4.11.
heya bustanutley, I am feeling that for just a trail rig diamonds may be tooo expensive.
But in one of your threads I read something about staying with 4.11 gears why is that? Is it because of the increased flex?
4.11s are stronger than lower gear sets. have to agree with wtf no 4.10/4.11 option? 80 series here have 4.11s factory. they run a higher gear set because everything is diesel?
whaaaaa?a Toyota axle that doesn't come in 4.10?
how is the gear ratio related to flex???
yessiree boss, 60 series cruisers come in 4.11...... I don't know if that is good or bad.......![]()
LC stuff is nice.
And yes I will most likely spend $2700-$3000US on the front diff alone, However for me to get a built, locked, 35-spline, high-steer Dynatrac to Darwin in Aus would cost much more initially, and exponentially more to maintain.
Hey Josie.
The super duty comes with a D60 front but I won't be able to get one to Darwin for under $2000. That's bog-stock standard.![]()
