First off I just want to say thanks to everyone in this forum, i have been reading and learning for years now. You guys are awesome and are the reason for my cruiser infection. I have not had a single problem i couldnt come here and figure out a solution to just by reading old threads.
That being said i am to a point of great frustration with my landcruiser. I have a 1990 FJ62 with 3fe. Engine has about 80,000 on it and everything else about 170,000.
The issue i am having has been going on for about 4 weeks now. The engine turns over and runs great. The problem only occurs after its warmed up. I have about a 20 minute highway commute everyday for work. When i stop at a redlight after the 15 miles on the highway the engine idles a little rough but only some of the time.
When i go to accelerate the engine stumbles, spudders, black smoke out of exhaust and sometimes surges. I can usually just rev the engine and after about a mile of her wanting to stall and spudder shell run great untill i have to stop again.
Today it got worse. I stopped at redlight after driving some back country roads and she idled just fine. When i tried to accellerate the engine stalled. She will idle just fine but whenever i try to accellerate she stalls.
Here are the parts i have replaced.
Throttle Position Sensor
Intake hose,(cracked and chunks missing)
O-rings for fuel injectors
fuel dampener
fuel pressure regulator
intake manifold gasket
Fuel filter
New spark plugs
New wires
The only thing left i can think of is the fuel pump.
This being the most expensive of the parts. With the problem being only after the engine is warm and has been running a while I didnt think it was the fuel pump. The check engine light only comes on while the problem is occuring then goes back off when it stops spuddering.
Am i just this much of a cruiser noob??? Can you guys think of anything that i could be missing??? Sorry for the long post just wanted to make sure i provide as much information as possible.
fuel dampener
Fuel filter
New spark plugs
New wires
