So I followed the FSM, I think: 93 Cruiser
1) Lined up crank pulley with 0 - TDC
2) One dot on the intake cam is facing two dots on the exhaust cam.
3) The service bolt hole on the exhaust cam is at the 12 o clock position
4) The timing chain sprocket slides on the intake cam with the pin at the 12 o clock position.
I turned the motor over by hand and all is good.
When I try and start the truck is sounds like it has no compression.
What did I do wrong?
Is it supposed to be two dots to two dots and one dot to one dot?
