Camo wraps any experience?
I've never seen anything like that before, it's crazy!
Thats not the type of camo pattern i was expecting to see, but i guess some people would like it. :meh:
I would never coat my ride with it though!
From what I have found out so far it will last more than five years, the removable 3M wrap does not damage paint. It will in fact protect paint from branches, rock chips, UV, etc. They also have perforated camo window film (=security, keeps interior cool). The question is does anyone have any experience with this product. I am wrestling with the question of whether it is my cup of tea. I already get stupid looks because my 80 is a right hand drive, with camo the urban nerds would probably stroke out. In my mind that would not be a bad thing.
I've done some wraps and own a company that installs 3M clear bras. I wrapped an entire car with the clear bra material as well. Couple things to consider. First, it will be the most frustrating thing you ever do in your life and you won't be happy with the quality but will simply have to shrug and say "Oh well" to have the experience acceptable. Second, you will never take this off even though it is removable. For starters, you will have several square feet of adhesive to get off of each panel, and you will also have razor blade cuts into the paint all over the place from trimming it (we don't do this, but there's no way you'll get good enough to avoid cutting into the paint on your first install).
Take a close look at all the trimming and edges - things like door handles, logos, vent grilles, roof rack, body panels that curve in two directions at once, etc. It's a bitch.
I think it is an individual taste thing. Finally from a safety perspective it will make your vehicle surprisingly invisible to other drivers as the pattern breaks up the vehicle into background clutter even in urban areas to poor drivers making snap decisions.
YMMV.
DougM
Take a close look at all the trimming and edges - things like door handles, logos, vent grilles, roof rack, body panels that curve in two directions at once, etc. It's a *****.
YMMV.
DougM
Thank you for relating your experience. I believe you regarding the frustration level this installation could cause. I never thought of the "invisibility factor" to other drivers. We have our fair share of drivers in the "poor" category.
I thought that was the point. :confused: ;)
There is an 80 around San Antonio that has this this done to it. I've never seen it myself (my wife told me about it), but if I see it again I'll be sure to try to take some pictures of it.
That 'real tree HD snow" pattern is the shiz.
A friend of mine has done it on his tow rig. He bought a new Mega Cab long bed Dodge thats just huge so he used the camo to trim out some of it and break up the massive white panels a little bit, he had it done locally and the lady did a nice job, i don't know about wrapping a whole truck in it though, another thought may be the "Ape wraps" ? i think its called. You design it and they print it off, just a thought.
there is a guy in the paint and body work section that did this on his 40, it actually looks pretty good. I'll see if I can find the link.
I own a sign shop and do wraps all the time. Here's one of my old rovers
I will say this if you've never worked with vinyl before. There is a reason wraps cost several thousand dollars. It takes a lot of experience and time. I can lay down the vinyl on a van in a few hours, but then spend 2 days finishing all of the trimming and wrapping of the edges.
80s have a lots of contours, and if you don;t know what you're doing, you'l have lots of wrinkles to deal with. I'd say consult an expert in your area and have his number on speed dial when you run ito problems. Make sure you do it in a garage and have heat around...because the vinly will not deal well with the cold.
HAHA!! oh...that was a classic...it is a camouflaged truck and you have never "SEEN" it. muahaha...oh....oh...god...sorry...thank you.:D
What are those? Gina's:confused:
