Cam questions
Kansastitty
Cam questions...Pinhead?????
I'm going through a '77 2F and have come to the cam. There are a couple of lobes that have some tiny chips or pits in the top of the lobe.
Should I replace it with a regrind?
Just install new lifters?
What about "resurfaced" lifters?
Go with an RV regrind cam?
Motor has 87K on it
Main use is DD
Only reason I'm going through it is that I bought it out of a rig and it is on an engine stand and it seemed like the right thing to do...maybe dumb?
I'm having the head hot tanked, new valve guides, checked for true and the seats recut.
I'm just putting new rings and bearings in it, no need to bore as the cylinders are right in the middle of factory clearances. Same with the bearings.
Hope I've included all the necessary info for an answer.
Thanks,
Ed
I think I would replace it with a mild re-grind. The lifters can be reground as well, unless you find a cheap source.
Since you are replacing rings and bearings a re-grind should be fine.
There is a place in Atlanta that does good work on re-grinds. I had one in a Celica years ago.
Reed cams - http://www.reedcams.com/
I would not hesitate to use them again. No affiliation, just got good service and a great cam.
Thanks, Brad. When you say regrind, you mean back to stock lift and durarion or with an RV grind?
Ed
ttt
I think I would go with the RV type of a re-grind. Reed will ask you what all you have done and can make recommendations as well. Or any cam place for that matter.
Ed,
I too am going through a 77 2F and opted for the RV cam from Specter 050-16-RV260 Camshaft With RV Grind-Fits 1958-8/92-No Core $139.99 and brand spankin new lifters from CCOT AFTL-933-13751-61010Price $141.82 Sale $109.73. Mine will also be a DD. I'm doing the work with the engine in and it's my first time. I'm having fun but it's a bit cold with no garage here in the NorthEast (single digits tonight).
Good Luck,
John
John, thanks. What does the RV grind offer? More low end grunt? That's what I assumed, but don't really know. Are CCOT's lifters good quality? What I'm asking is...would it be better to regrind the OEM or go with new aftermarket?
I am waaaay new to this engine rebuild thing. Fortunately, I have a Guy with 35 years experience with everything from Vw's, BMW's, to 2 Ton Chebby's and tractors. I'd like to use as many OEM parts as possible. Been trying to talk to CDan and we have a great local Toyo dealer here in Kansastitty as well. Just don't know as much about cams as I feel like I should now.
Nice to know there is another rebuild newbie out there!
Ed
Brad, I sent Reed an email about my motor specifics and asked his advice. Thanks for the lead!
Ed
The last time I talked to them they quoted me a really low price on the re-grind. It was about a year ago.
I know even less. I'm not sure of the exact benefits but I believe it is low end torque. The cam lobes are steeper/more pointed resulting in I believe less valve open dwell. People on the board have asked the pros and cons without,as far as I've seen, any detailed responses based on experience. We'll see once we get it rebuilt. I actually have no experience with the 2F only the F in my 72. I bought the 77 through Vintage Offroad (Greg Mushro) who, I've read, should be avoided. I bought over the internet through photos not knowing which of the 9 farm used FJ40s (A farm in Merced Calif) I would be receiving. I ended up with the best one with saginaw power stearing and the engine actually ran. It also contained a living Black Widow in the front rim. I sprayed it with bug killer.
Oh ya. The lifters seem of excellent quality and seemed to be very reasonabley priced.
Is there anyone else out there that purchased one of the other rigs and what is your experience (don't mean to steal this thread)
keep us posted on the progress
John
Pics of the cam...
Here is what I'm concerned about...
Now questions:
Do I need to replace the cam?
Regrind or new billet?
RV or stock?
And DocB...you laugh funny.
When I pulled my cam it had the same pit marks but more importantly the lobes were flat /worn on most with only a couple that looked good/not worn. I don't know the price of having them machined but I thought $140.00 was cheap enough.
Are your lobes worn? They appear to be but maybe it's the angle/reflection. I just learned this weekend from here, that the cam is off centered to the lifters in order to facilitate lifter rotation and even wear.
John
Yes, i read that thread, too. Seems like a good design to me. I have done some research and found lots of info but none on the height or dimension of the lobes. That would be the best way for me to check. If anyone has that dimension, please post it. The cam is cast/forged, and then ground, so some pits are to be expected?
I just don't want to be cheap about a part and destroy my goal. I've heard that a regrind puts more strain on the valve train?
Gots lottsa questions here and I'll admit to being an engine rebuild noob.
Where is PinHead or Poser????
Really need an F/2F guru here.
Ed
When in new or nominal condition the machined surfaces are perfectly smooth. Pitting is from wear and while it is normal it is not right or good.
I have seen much worse still running in the engine. But for the cost of a reground cam, replace it (and the lifters of course).
In theory the smaller base circle of a reground cam puts more stress on the lifter face. In the real world, in a Cruiser, with the cams that are run in this motor it is completely irrelevent.
Mark...
