cam bolts
canada
Does anyone have a list as to which bolts are needed to replace the lower control arm bolts if they are seized? Bolts, nuts, sleeves etc? Want to make sure I can order all of what I need. TIA
I don't have the part numbers handy, but don't use aftermarket. I had to replace them, with OEM, gave me so much grief (never stayed torqued)
You're talking rear lowers, correct? Same bolt/nut combo fore and aft:
90119-14118 bolt
90178-14011 nut
07,yea front LCA. but its like 5-6 part numbers per side i think between the bolts, nuts, and adjustment shims. This is the company I am thinking of getting the bolts from
Ah, cam bolts, forgot what we were talking about.
Here's a diagram:
I had one seize on me years ago and needed a sawzall to get it off. Good luck.
