Cam Bearings
BEND,OR
I'm replacing my camshaft . When I removed my cam, I discovered that the last bearing surface had groves in it but the other 3 bearingf surfaces are smooth. Now I'm thinking I should replace all the bearings with the new cam..
How do you change the cam bearings ???
There is an SST for that purpose. I had the machine shop do mine when rebuilding a 2F. I know there is someone here who has figger'd out a shortcut.
GL
Ed
I thought replacing the cam bearings were easy, But the block was out of the truck. The bearings are tapered, largest towards the front. A set of bushing drivers worked for me. make sure the oil holes line up, could be a costly mistake. And on the 2F the front bearing has an oil slot cut in it, The slot goes out towards the gears because that oil hole is off set
